Documentation for NEWTAB and FINDEXISTING?
Neither of these appear in the PDF or online HTML. Are they documented somewhere?
Regards, AB
A substantial amount of documentation on these topics can be found in your DOpus directory.
See the Opus 82 Changes.pdf
Regards,
:opusicon: porcupine
Thanks for that pointer. Now for the real question...
Set SOURCE=Left
Go C:\ NEWTAB=findexisting OPENINLEFT
This works as expected.
Set SOURCE=Left
Go /somealias NEWTAB=findexisting OPENINLEFT
This always opens a new tab whether or not the folder referenced by "somealias" is already open in the left pane.
Working as designed?
Regards, AB
Ahhh... a trap !
It's a good one though .
OK aussieboyke,
I haven't verified this yet, but I believe you.
I'd say it's not working as designed !
Aliases should be global .
I'll get back to you on this.
Thanks !
Hello aussieboykie,
I also get this result.
I created an Alias called Island for the directory E:\Photo Archive\Some Folder\Some Other Folder .
The command Go "E:\Photo Archive\Some Folder\Some Other Folder" Newtab=findexisting
opens a new tab only when there is not already a tab "E:\Photo Archive\Some Folder\Some Other Folder" .
In that case, the "E:\Photo Archive\Some Folder\Some Other Folder" tab becomes active .
However, the command Go /Island Newtab=findexisting always opens a new
"E:\Photo Archive\Some Folder\Some Other Folder" tab,
whether or not "E:\Photo Archive\Some Folder\Some Other Folder" is already a tab.
I'd tend to think this is not by design and is really a bug.
Very Good observation aussieboykie !
Regards,
I would imagine the logic in the findexisting argument/feature simply does not 'evaluate' the directory alias... and probably wasn't 'designed' to :slight_smile:.
Hi Steje,
Yes, that has some logic to it.
However, there is also logic in the fact that Newtab did evaluate the alias.
A Newtab was in fact created and was hence made the active tab.
How can it be that the, as I imagine it, lower class member findexisting does not inherit that information ?
You know much more about this than I do Steje, so please correct me.
Well, I would hardly say that I know any more about it than any other user... it's just a guess:
  • Newtab=findexisting
    --- "E:\Photo Archive\Some Folder\Some Other Folder" not equal to "/Island"
  • Go /Island Newtab
    --- lookup "/Island" alias
It's all academic and the bottom line is neither of you are doing anything 'wrong' that you could change to get it to work (I presume). Whether it's a bug, design oversight, woopsy, or feature request is really for GPsoft to answer :slight_smile:. I'd submit it to their web support page and see what kind of response you get... and then flame the Beta Tester lamers for not finding this hole (joking).
