Does match casing based search works properly?
Hi,
following searches (f.e.):
mono
Mono
mono
Mono
mOnO
always show the same results, no matter if matching case and/or use wilcards is slected or not. Is this normal? How can I find exactly the "mOno" string?
Thanks
The case-sensitive checkbox in the simple Find panel relates to the file-contents search box directly above it.
I think filename searching is always case-insensitive right now, sorry.
Ah! Ok.
I saw that windows search also lacks of this feature :frowning:
I'll suggest it to main site.
Thanks
