Dopus 10: Sort order
I have a custom button which worked as desired in previous versions, but doesn't give the desired result in Dopus-10. It is:
. Set KeepFoldersAlpha = toggle
In previous versions this always toggled between an ascending-order alphabetical sort of my folders and a descending-time-sort (i.e. newest modified folder listed first) of them. This is exactly what I need.
Now I find that the folder list is in ascending order if the files in list are in ascending order, and in descending order if the files are in descending order. That is, if I have files sorted according to the Modified tab, clicking the tab again inverts both the file portion of the list and the folder portion of the list. This is not the way Dopus worked previously. The Modified tab used to affect only the file portion of the list.
Can you please fix this in the next release?
See this thread:
Sort directories alphabetically but files more recent first
Thanks. I have left a follow-up message there.
