Dopus 9 and media player 11
hi
i've downloaded some files from internet with .wma extention but containing a video flow and when i click on the movie plugin is by media player 11 window inside the movie plugin.
i avow that is great because i can get all the media player 11 feature inside the dopus movie plugin.
i'm wondering how i can change this tip for all my videos files extention not only wma!!!!
thanks in advance :slight_smile:
WMA file with video? Weird!
It's probably because the ActiveX plugin handles .WMA by default, which will mean Windows Media Player is used in the viewer window/pane. The ActiveX plugin doesn't handle other extensions like .WMV so that they drop through to the Movie plugin.
If you want, though, you can add .WMV (etc.) to the ActiveX plugin's list of extensions, via Preferences -> Plugins.
Last time I tried viewing video via ActiveX & Windows Media Player the video's aspect ratio wasn't preserved which was very annoying. The Movie plugin does a much better job, IMO.
thanks nudel for this quick replay :slight_smile:
