Dopus Crashes on Right click in tray icon
For some reason, my directory opus crashes after I right click on its tray icon.
It happened yesterday for the first time after having accessed a 2GB SD drive on my Toshiba M200 Portege Tablet with XP2 SP2. I installed the newest version of dopus, just to be sure, but it happens every time. Especially when having a USB flash drive or SD card installed.
Any suggestions?
Something odd happened to your image attachment. :slight_smile:
Have you modified the tray icon's menu at all or is it the default menu?
Hi,
I did not change the tray or anything on the taskbar. Dopus crashes immediately when right-clicking on the icon in the tray.
When you installed the latest version was it 9.1.0.3 or 9.1.0.4? (9.1.0.4 was released earlier today so it may have appeared after you updated.)
Will do. Thanks.
