DOpus doesn't resize its contents
Does it make any difference if you disable Start8?
No since I don't have it for a while (or any other start menu replacement).
It was visible in the screenshot you posted though?
Hmmm, there is a possibility that Start8 permanently changed the icon, but, I believe that is the default icon for Win8.1.
Oh ok, red herring then. Are you running any other tools on that machine that affect window behavior in any way?
Two things I can think of:
  1. On console I have two monitors. When I connect over rdp, display configuration switches to only one monitor (DOpus is on primary monitor).
  2. I have ATI drivers. I believe they have some windows repositioning logic (hydra-something?), but, I don't knowingly use it (I don't even know what features it offers).
