I have a registered copy of DOPUS 10 on 64bit Win7. Can I download and install 32 bit version of DOPUS on virtual machines VMWare and/or XP Mode on the same computer under the same license? How about DOPUS 11, which I'm considering buying?
Yes, as long as it is the same physical machine that Opus is licenced on, and you are the only user, you may use the same licence within a virtual machine running on the same physical machine.
