Am I the only one who deletes systematically the DOpus desktop shortcut after installing a new version?
I have this shortcut in my task bar so I didn't need it on my desktop and as it is installed in public desktop, it requests admin privileges to remove it which means I need to enter my admin password. (I'm logged every time in Windows as standard user).
1- So, Is it possible to have a simple check box during installation which allows to prevent desktop shortcut installation? It will be great.
2- Is there a way to prevent DOpus to request a system reboot after installing a new version? I mean, maybe closing manually everything which has to do with Opus could make the program works without the need of a Windows reboot. Does it work normally If I decide to start the program without rebooting Windows?
Well, it is not like if there are dozen of updates per month but I don't like to reboot my system and I prefer to use the hibernation so I don't need to close my opened programs (with opened files). As there are updates for Windows, I need to reboot at least one time per month. My firewall needs a Windows reboot also and I needed this week to reboot because of the new version of snagit. Now, few days later (=today), DOpus has been updated so I would like to know if there is a way to make Opus works without the need of a reboot.
