DOpus.LoadImage automatic rotation when required
If an image is previewed in a dialog control along these lines..
dlg.Control("staticPreview").label = DOpus.LoadImage(someImageFileItem)
..and the image was inadvertantly taken upside down the preview is shown upside down. When the same image is displayed in the lister viewer or standalone viewer it is shown the right way up so DOpus evidently recognises that the orientation is out by 180 degrees. I'd like to request that dialog control preview behaves the same way as the viewers do and automatically rotates as appropriate.
You can set the Control's rotate property to rotate the image, and use the file's metadata to get the appropriate rotation amount.
