I have a problem - for some time now, I don't know when exactly it started, Dopus always starts with the same set of six tabs - regardless of the tabs when it last closed.
I went to preferences / launching opus / startup and tried all of the other options like "don't open any listers" but none of that works. It always behaves as if "default lister" were chosen. Apparently the "default lister" is made of the six tabs it always starts with. How can I make it do what I choose in preferences like "open listers that were open when last closed"?
Great thank you! That's a nice workaround. Actually the program should do what I choose but if the default lister is updated every time a lister (or the program) is closed, the end effect is the same.
It does do what you tell it. You're confusing closing the window with exiting the program. The program stays running by default, and there are separate options for both.
(There may also be multiple windows open at once.)
