I'm getting this esoteric error message popping up on my screen at random intervals (I'm not using my newly installed dopus12 on my Win7-x64 PC at these times but it's running in the background)...
dopusrt.exe -Entry Point Not Found
The procedure entry point SafePathAppend could not be located in the dynamic link library dopuslib.dll.
Rebooted my Win-v7-x64 (16gb ram) environment here (a traumatic experience I don't normally confront more than once a month or so) and the very first error message pop-up window confronting me was the exact same one I reported above.
At this stage, it looks pretty certain that I've paid ~aus$75 for an upgrade to a beta-grade v12.2 release...
I hope you can dissuade me of this sad notion at your earliest convenience...
Thanks for your continuing attention & help with this challenge I'm dealing with here.
Bill B.
PS: Where in the app can I find an "about" window that will display the current release info of my loaded exe? I went through your v11 to v12 (PAID) upgrade routine... afterwards my running app looks EXACTLY like my same-ol v11 app and I can't find anyway to get the running app to tell me what version/release/build it is? Is there a way to determine this??
Rebooted again... and it looks like the re-install finally took. Sorry for the previous angry outburst... rebooting my environment is very stressful and I attempt to delay doing this as long as I can.
