When I double click on any file name or type I get an error. OPENing the file from the right click menu works OK. How do I fix this? The error is something like:
An error occurred making link "go":
An unknown error occurred.
Thanks for your help.
Go to Settings -> File Types -> All Files -> Events.
If anything is assigned to Left double-click, delete it.
Do the same with the All files and folders file type.
(Do not do the same to the All folders file type, which is supposed to have a command on the left double-click event.)
