Hello Directory Opus users and support team,
I have had an issue that has just occurred recently where if I click on one item within the listener then another within 2-3 seconds it performs a double click action instead of the expected single click action ( such as selecting an item ).
I am using version 12.31 and have not modified any settings in over a month in Directory Opus, this issue has started in the last week.
Is there a way to set double click speed, or is this a known issue? ( was unable to find a similar problem on the forum ) my expected time between clicks should be 0.3-0.5 seconds.
This issue only happens with Directory Opus, other file managers and Windows applications work fine.
Thank You
EDIT:
Also is it an option somewhere to treat each file separate so even if I clicked on each file super fast within 0.2 or less seconds the second clicked would not open.
