Download speed is extremely slow
Hi,
I just bought Directory Opus and went to the download page to get the product. The download is extremely slow. Chrome suggest I can open the file in 24 hours. There is usually no problems downloading from this computer. My location is Oslo, Norway.
Please fix this soon, or help me to refund.
Regards,
Bjarte
Out of interest, if you open a DOS prompt and type ping cdn.gpsoft.com.au what IP address does it show?
Try downloading from this link and see if it’s quicker: https://www.gpsoft.com.au/files/Opus12/DOpusInstall.exe
Pinging 894938763.r.worldcdn.net [91.109.247.145] with 32 bytes of data:
Reply from 91.109.247.145: bytes=32 time=27ms TTL=53
Reply from 91.109.247.145: bytes=32 time=31ms TTL=53
Ping statistics for 91.109.247.145:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 27ms, Maximum = 31ms, Average = 28ms
Edit: your link seems to work. Thanks
Thanks, we'll report the problem to our CDN provider.
