Drag and drop problem
I've been using Dopus on Windows XP for many years and have always loved it. A few days ago I installed Windows Vista 64bit version and now have the 9.1.1.5.3222.x64 version of Dopus installed. It works great, but one tiny thing annoys the hell out of me.
When I drag and drop multiple files from a lister to f.ex. the folder tree, the "box" of the selected files is not transparent enough so it covers the folder tree and makes it very difficult to see where I'm supposed to drop the files. Is there a way to adjust this transparency?
Anders
Hmm, I never drag completely over the tree folder but rather just to the right of it ... The folder that I want to drop into gets well highlighted and I can see the drag box and the highlighted/selected folder both.
I do see a problem when dragging from file display to file display tho .... the higlighted folder is just barely so and not easily triggered since the drag box must be directly over the folder name .... not just the name field.
You can change it here:
Thanks Leo, that worked perfectly :slight_smile:
