Hi all
I'm using Dopus 8.2.2.x on Win2kSP4
and encountered a problem that
the drag-move drag+shift displays and performs copy
instead of move
any ideas ?
thanks
Tom
Hi all
instead of move
any ideas ?
thanks
Tom
Go to Settings, File Types and edit "All Files and Folders". See what the drag & drop with shift event is set to do.
Ah thanks
Ok I narrowed the problem
the move works but
When I drag the file with shift held down over
the destination tab name the icon being displayed is
the copy icon not the move icon
thats what confused me
is it a problem?
I think that's a known issue.
