I've just installed DOpus on Win 7 64 bit. Drag & drop doesn't work. Nor does shift click for selecting files/folders. When I click, the file/folder is selection is toggled.
I chose the defaults when installing. I haven't changed any option. Ideas?
You've switched into Power Mode by mistake. Change back to Details Mode and things will go back to normal.
That was it, thanks. I didn't see it on the FAQ, so you might want to add this.
By the way, you can configure the power mode to use a differently looking grid, so you can distinguish power/details modes much better.
