Hello
From Directory Opus (in dual pane or several windows), I can't use the right button to drag & drop a file, I can't see the icon moving and the context menu is not showing up and i. This is really annoying when I want to extract some archives for example
This is working fine on the desktop or I launch the Windows File explorer.
Is there any settings that control that behavior in DO that I may have changed ?
Thank you
Nicolas
