I uninstalled and re-installed DOpus 9.1.3.0.3449.
I had to install it in compatible mode, because it forces it. It tried it in Vista compatible, but it was still, after a couple re-boots, taking over my Documents folder.
So I installed it in XP-Mode.
Now, aside from the fact that the Aero-Glass is gone on DOpus, so are the drive buttons.
How can I get these back?
Any idea, now that Windows 7 is RTM, when DOpus will be Windows-7 ready?
But now, How do I put the drive letters back under the icons without having labels under all the icons? 'Cause if I do that, the toolbar gets too large all together.
Right out of the box, it seems to work better with Windows 7 (works in native mode instead of Compatible mode) , and does not seem to have the issues with my keyboard the the "prior" version did.
I understand it is still beta, but it seems more pliable already.
