Drive letter in Tabs fails when Tab renamed
Hi All,
Can anyone confirm that adding drive letters to Tabs does not work when the Tab has been renamed? It seems that the drive letter is added to the name string only if the name has not been modified, even if back to the original name.
This in Vista 32.
Thanks,
Mike
Yes when you set your own name for a tab that is the only label it will have. To return to the default, edit the label and clear out the string completely.
Got it.
Thanks Jon.
