Dual Pane - Right hand pane has gone miniscule text whilst left hand pane is massive. Preferences will not fix. Do I need to re-install? (has been OK for ages)
Ctrl + 0 (zero) will reset the active side's font size by default, the same as in most web browsers.
Perfect ... Thank You very much, Leo.
