Duplicate Files - Delete Button - Fails if recycle bin too small
Hello,
If the recycle bin size (per drive) is smaller than the combined size of the files you plan to delete, the find duplicates "delete" button fails very mysteriously with no error and no hint. Should probably say "go increase size of your recycle bin" or "just delete the files".
Only when I was getting together information to file a support request was I able to put together what was actually going on behind the scenes...
Thanks,
posting here rather than start a new topic.
Im seeing problems with delete too, although i have turned off recycle bin, and deselected the option in opus prefs to use recylebin and still have same problem. BTW my select button also does nothing. Am able to use ccleaner duplicate in same folder without any issues.
WIN 7 64bit latest opus version
