When I hit the button to make the find / duplicate / sync panel appear, it's default size is too small and some the panel UI elements are cut off---one has to use the scroll bar or drag it larger. (see pict) The default size is clipped for all three tabs (find / dupes/ sync)
If I hit the tiny chevron "minimize" icon on that panel, and then unminimize it, it resizes automatically to a "correct" size (one that doesn't require scrolling for the current tab panel). Likewise if I manually resize it and then close it, Dpous will remember that size next time I open it -- but only in for that lister window. Any new listers will revert back to the clipped / scrolling size. It doesn't matter how big the host lister window is, or the contents, or what toolbars I have enabled at the time.
It's kinda annoying to have to resize that panel every time. Does this happen to everyone, or is it just me? Is there a reason for this behavior, or is it a bug?
