Embedded fonts in backup
The biggest pain when restoring settings is the lack of used fonts on the new system. Is there any way to add non-system fonts to the backup?
Which fonts are installed is part of the Windows install/configuration, not part of the Opus configuration.
Assuming the fonts you use don't change often, making a folder/zip of the font install files would be enough. You can then install them once on each new computer and be set.
