Can it be configured by default to display @ Original Size?
Also does it support any keyboard shortcuts for movie viewing like ff,rewind,pause
It remembers the previous zoom setting so if you set it to original size it will stay that way until you change it.
It responds to the standard "media" keys, if your keyboard has them.
It works only for the current session.
It is not remembering. It seems I have to set it EVERY time I reopen the app. I set to original size, quit the program reopen and BAM it set to autosize.
Looks like only the standalone viewer, and not the viewer panel, remembers its zoom setting between uses.
File a feature request if you want it.
