Ending Backslash in location's path
Hi guys
The default presentation of a directory path in the location is like:
c:\temp
or
\unc\server\c\temp
As I very often do copy/paste of the path string in a lister, I would be happy that the path is shown with a ending backslash ''. Upper examples would look like
c:\temp
or
\unc\server\c\temp\
Is there a way to add the \ as default in any lister's location path?
It's the one and only thing I miss in Opus :slight_smile:
Best regards
Peter
You could make a button or hotkey which copies the current path to the clipboard with a backslash on the end, if that would help?
Hi Leo
Yes, that could be a solution. I'll try that!
Thank you and kind regards
Peter
