Nice idea. I've configured Opus to do the same here now.
I'd tried setting the double-click event to go up before but I found I kept double-clicking by accident and it got annoying. Accidentally clearing the filter will probably not bother me, though. (Time will tell.)
Thanks for mentioning that as I hadn't thought of it and it's freed up a toolbar button.
[quote="Zion"]You can define doubleclick (an empty area in the lister) to run any function that you define.
I use filters all the time and doubleclicking any blank area in the lister engages my default filter.
I love that function![/quote]
Thanks for this great workaround (hopefully the double-click in filter area will be implemented in the future).
One problem though:
The option to run a custom command when double-clicking is greyed out in my options. I can only enable the "goto parent folder" option. I do see the option to enable a custom command, but as said - it's greyed out.
Why could that be?
Thanks - Peter
PS: Also any feedback on not being able to clear the filter history?
