Entries in "Send To..."
Hello,
when i right-click files in DOpus and enter "Send To..." the
CD/DVD-drive and "Email-Recipient" are shown. This is kind of strange,
since explorer doesn't show them, because the latter is hidden (i use
The Bat! and not Outlook (Express)) and the CD/DVD-burning services
that Windows XP offers, are disabled (in service management and in
DOpus). Is there a way to get rid of these two entries?
Have you had a look in your SendTo folder? That's where the items in the SendTo menu come from in both Opus and Explorer.
At least on WinXP, the default location is:
C:\Documents and Settings\username\SendTo
Replace "username" with your username.
yes, i did and i got rid of everything unwanted expcept "CD/DVD-Burning"... Service is deactivated and no other app except DOpus shows it anymore...
[quote]nudel wrote:
Have you had a look in your SendTo folder? That's where the items in the SendTo menu come from in both Opus and Explorer. At least on WinXP, the default location is:
Replace "username" with your username.[/quote]
Also, don't forget to check the All Users Send To Folder:
C:\Documents and Settings\All Users\SendTo
(Again on Windows XP)
[quote]
C:\Documents and Settings\All Users\SendTo[/quote]
I checked all SendTo folders now, but nowhere is "CD/DVD-Burner" to be found... and no SendTo folder in "Documents and Settings\All Users"...
