Error in Script SelectNewest
in the script SelectNewest [1] there is an error in the sort line.
The "If" is written in capital letters, but should be written in small letters.
All if's as see in the next line
If (a.modify < b.modify)
should be
if (a.modify < b.modify)
[1] https://www.gpsoft.com.au/help/opus11/index.html#!Documents/Scripting/Adding_a_new_Internal_Command.htm
Thanks, we will update the manual the next time a new version is uploaded.
(Note that only the Opus 12 manual is being updated. The URL points to the Opus 11 one, which won't be updated.)
