hi,
in explorer if you cut a file ,
icon becomes grayed (until you paste).
If accidentaly you cut a file, you can press ESC to restore normal icon and cancel cut.
In dopus pressing ESC seem to do nothing.
thanks
hi,
thanks
I guess GPSoft didn't notice Explorer did this. I didn't know it did, anyway.
You can do the same in Opus by copying (ctrl-c) something else to the clipboard. Instead of Esc press ctrl-c.
Or just paste it back into the same directory.
