Evaluators - Need tip to migrate existing JScript
Hi!
Currently using this JS code to populate a column's content using old style scripting.
//extract date from filename
var date = String(scriptColData.item.name_stem).match(/\d{4}-\d{2}-\d{2}/);
//extract years of warranty from filename
var warranty = String(scriptColData.item.name_stem).match(/\[\d+.*\]/);
How would one do this with an evaluator code?
Just tried:
date = RegExS(name,"\d{4}-\d{2}-\d{2} (.*)");
Output(date);
But this obviously returns True or False if a filename fits the conditions or not.
I would like to extract the "date" from a filename in var date and the last part of the filename in variable warranty, eg.
2022-03-04 TeVi Severin Microwelle [2 Jahre Garantie].pdf
name = "2022-03-04 TeVi Severin Microwelle [2 Jahre Garantie].pdf";
date = RegExS(name,"(^\d{4}-\d{2}-\d{2}) (.*)", "\1");
rest = RegExS(name,"(^\d{4}-\d{2}-\d{2}) (.*)", "\2");
Output(date);
Output(rest);
If the date might appear in the middle of the name, take out the ^ at the start of both patterns. (But you'll only get the text after the date in rest, and lose any text before the date.)
I did a small edit to RegExS [Directory Opus Manual] to include an example and state which replacement syntax it uses (since some things use \1 and others use $1).
I was near the solution, 'cause my other coding was like this, without the round brackets
date = RegExS(name,"\d{4}-\d{2}-\d{2} (.*)", "\1");
Output(date);
Thanks Leo for this prompt answer and help!
May I come back and ask for another tip regarding RegExS function?
Continuing the example above, I would need the last part of the filename starting from
When using
warranty = RegExS(name,"(\[\d+)", "\1");
Output(warranty);
I get
--> (empty result)
I expected [2 as a result in variable warranty, please see: regex101: build, test, and debug regex
Where is my fault?
Edit: Just found my error: It's all about grouping :wink:
warranty = RegExS(name,"(.*)(\[)(\d+)(.*)", "\3");
Output(warranty);
Gives me just the digits, in my case: 2
I'm not sure why it's needed in this case (need to look in more detail), but this seems to work:
warranty = RegExS(name, ".*(\[\d+).*", "\1");
Thanks Leo, see my edit in my previous posting :point_up_2:
Try RegEx instead of RegExS.
Continuing my JScript conversion, I hit a new challenge: date calculations!
Given this evaluator script
expiration = DatePart(Now(),"YYYY-MM-dd");
output(expiration);
results in 2023-12-29. Now I want to add e.g. 2 years to this date.
While this was pretty easy before, using a JScript
var warranty_yrs = 2;
var df = DOpus.Create.Date(date[0]);
df.Add(warranty_yrs,"y");
it occurs to be a somehow bigger challenge with Evaluators :grimacing:
Further tests showed that this might be one solution:
expiration = DatePart(Now(),"YYYY-MM-dd") as date;
expiration = (expiration + 2 * 365 * 24 * 60 * 60) as date;
output(expiration);
At least I almost get the desired date: 2025-12-28.
I did a quick test, using parts of my old JScript and the result is however 2025-12-29.
So, JScript date objects respect leap years like 2024, the manual date calculation above, does not of course. For some obvious reasons, I do not want to add leap year detection, you know :slightly_smiling_face:
Is there a better way, using Evaluator functions?
You can add two years to a date like this:
expiration = Now() + "2y";
Note that the YYYY code for the DatePart() function returns the ISO year, not the calendar year, which can differ around the end of the year.
Wow, did not test so far, however this should be part of the documentation !
Thanks @Jon!
Edit: Works perfectly, used like this in my context (simplified):
warranty_yrs = 2;
expires_date: date = Now();
expires_date = expires_date + Format("%1y", warranty_yrs);
Did not found an easier solution so far for a dynamic date calculation other than using the Format function.
