Everything Portable works with v13
Little feedback to v13 & Everything Portable.
I'd read that v13 wouldn't work with ES portable and this was almost a big letdown for me, but it seems, they do work fine together.
Portable or not, it is definitely not the ES system service DOpus is looking for; as long as ES is visible in systray - no open window is needed - DOpus recognizes it a few seconds later after you start ES in the find panel. Both local & global searches work.
If you are using an alpha version like I am, set "alpha_instance" to false in advanced settings and restart ES. And voila!
