Sometimes (I just can't figure it out exactly when this happens) whenever I use EverythingInterface.Start() in a script , EV doesn't start and instead that method returns false. So, something like this in the Script Ad-Hoc Editor :
The most likely thing is that Everything isn't starting up quickly enough. Opus waits 2 seconds for its control window to appear before giving up and failing.
(For me, it starts up in under 50ms, so 2 seconds seemed like a safe buffer).
In the next update we'll add an optional parameter for the Start() method so you can make it wait for longer.
Correct me if I'm wrong, but I imagine the timeout is related to how long Opus waits to detect if Everything has initialized. That is, Opus starts Everything, tries to detect it for a maximum of 2 seconds, and then EverythingInterface.Start() returns the result of that operation. Even if Opus doesn’t detect it in time, Everything should have started, right?
To emphasize, what happens to me sometimes is that Everything doesn’t initialize, even after the timeout.
