I am having problems with 500 files copied to my system with location/filename exceeding NTFS limit 255 chars, which I cannot delete. Could anyone suggest a way I could use Dopus to
a) Filter them (eg using Flat View)
b) Truncate the location/filename to below 255 chars
Not sure if it's location/filename or location+filename. The software I'm using to burn (& I've tried a couple of tools, Explorer & Express Burn) keep stalling & failing on these 500 files before burning to DVD.
I was trying to use Dopus to isolate them, and then rename them. eg truncate the location and/or filename with ~ after 250 characters.
