Hi!
I just bought 3dBrowser, software that enables icon/thumbnailview for windows. But Dopus in some way override this thumbs for obj files. I tried to sort it out, but cannot find remedy.
Can somebody point me right direction?
Regards
Adam
Hi!
Regards
Adam
Go to Preferences / Viewer / Plugins, select Text-File Thumbnails and click Configure.
You can then add file extensions (e.g. .obj
), or file contents (e.g. # OBJ written
and similar things found at the start of the files), to the two lists on the right to exclude certain types of files from getting text thumbnails:
(Note that this is only needed if the files look like text files.)
Thank you very much!
User support here is incredible.
I like the new site too!
Adam
