Explorer Replacement Dialog
Hi guys,
Can anyone explain what the highlighted item is in the explorer replacement dialog...? I don't recall it being there before.
Cheers
Roly
Probably a virtual folder tied to some software that you've since uninstalled. Might as well select it and delete it from the list.
Cheers Leo, job done.
