Export to USB and toolbar icons
Some of my icons have real paths like:
C:\Program Files\GPSoftware\Directory Opus\Icons\397.ico
Will this function properly?
Also I used a couple from the Dopus 8 Icon Set and it does not get exported.
If you want icons to export to USB, then you should be putting them into an Opus Icon Set... Not sure why you're Opus 8 icons are not exporting though... And they're definitely coming from the Opus 8 Icon Set included with Opus v9?
Steje, you need to rethink your location field :stuck_out_tongue:
Cows don't have b@!!$...
done...
:laughing:
