Extended replacement - dialogue
The replacement dialogue which is opened while copying about an already existing file should be extended around another function.
the " Automatic renaming " should be extended so that it also Is to be allowed to rename possibly after a defined sample automatically.
How one could manage this is not quite clear to me yet, perhaps it would be meaningful in addition simply to use "normal" renaming dialogue one starts about a switch(counter) within the action window.
Thanks !
Stefan
Well, in the Confirm File Replace dialog... it could be nice for the current Replace->Auto-Rename/Auto-Rename All menu option to be expanded into a sub-menu to show a list of configured 'Auto-Rename' presets... or maybe just a list of the currently implemented 'Rename presets' rather than a new class of 'Auto-Rename' specific presets... Good idea.
