F2 behavior dependent on amount of selected files
is it possible to make F2 use inline renaming for a single selected file and the advanced file rename dialog for multiple selected files?
Why don“t you use a separate button for that? The code is Rename advanced.
Change the F2 hotkey so it runs Rename INLINE=single
awesome thanks
