Failed rename retry changes rename dialog settings
When using a script to rename, and the rename fails, and you select the Retry button in the error dialog, the Rename dialog opens again, but the settings have changed. I think they should be restored so the retry can be modified slightly to fix the problem.
You can select the "Last Rename" preset to get them back.
But shouldn't DOpus pre-select Last Rename then, since it already preselects the script in use (but which is no longer usable because the retry causes its settings to change)? In other words, DOpus has put the retry in an unusable state.
Yes, makes sense.
Confirmed fixed in 10.5.0.2.
Thanks.
