Fast Drive changing
Hello,
I just hat to switch from Altap Salamander to Directory Opus and what am realy missing (besides other) is the fast drive change with Shift + Drive Letter (e.g. Shift-C > Drive C, Shift-H -> Drive H, ...) - is this possible with DO9?
VL
P.S. Nevertheless DO9 is nice compared with Salamander, but what's missing (for me) is internal ISO, 7z support and proxy support with FTP
You can solve this creating a new hotkey with the "Go"-command.
For example:
Hotkey: Shift-C
Command: Go C:\
I thought on that, but hoped there's a few-line-easy-script-solution by the pros here.
Nevertheless I added the 24 hotkeys and it works.
Thank you,
VL
[quote="Venia Legendi"]I thought on that, but hoped there's a few-line-easy-script-solution by the pros here.
[/quote]
But there is. Edit appropriate config file with a script langauge of your choice- they are all just XML files.
X.
