If I select Favorites > Add To Favorites and create a new Branch, it works allright (shows up on the Favorites drop down list). If I however select Favorites > Edit Favorites and add a new Branch there, it doesn't show up on the list. Is this a bug or some problem with my system?
Is there a way to clear/reset the Smart Favorites list? If not, could it be implemented?
Favorites branches will only appear in the menu if they have something in them. If you create an empty one then it won't appear (which makes sense as it'd just be an empty menu when there's nothing below it to actually select).
I think it depends on how you choose to organize your stuff. You could build a structure of branches first, and then add content to them later, for example. I do that sometimes myself in different other programs, and I'm used to folders being visible there whether they're empty or not.
