Favorites Shell Link?
Good morning! How can I create a SHELL LINK to open several DOpus Favorites as new tabs in the currently running DOpus Lister?
You want to create shortcuts to some folders? Or something else?
I just want to create a SHELL LINK (Windows shell command line) to open several DOpus Favorites as new tabs in the currently running DOpus Lister.
Executing this command in Windows Run should open specific DOpus Favorites as new tabs in the currently running DOpus Lister.
You can use dopusrt.exe to run commands from outside of Opus.
Alternatively, create a button that does what you want and then drag the button to a folder to create the same thing as an icon you can double click from the shell.
Or you can set Opus to open folders in new tabs by default, so you can then use simple folder shortcuts to open them.
