Rereading the FAYT section of the manual reminded me about # (Range) and : (Select). These are both very handy ways to select items. They would be even handier if they could be extended to optionally add files to an existing selection. Let's say I have some files selected..
..and I want to scroll to the next page and select some more. If I use # to open a new Range prompt, the moment I type an index number into the prompt, the current selection will be dropped and replaced by whatever new index range I specify. I'd like to suggest that doubling up on the # and : triggers could be used to extend a selection rather than replacing it. i.e. if I typed ## and then specified a range, the new selection would be added.
Regards, AB
