Feature Suggestion for Synchronize Display
See the attached view.
I would request that in the left pane a blank line be above that first file for two reasons:
- So it is clear that the top file in the right pane is only on the right AND
- So it is clear that the next to lines are on both sides, one more recent than the other
This example is intentionally simple so the request is clear.
If many file pairs like this are found, it is very hard hard to tell what is going is on. You'll see a long list of files on the right and a shorter one on the left AND the files on the left will not line up with any on the right. Neither 1 or 2 above will be clear.
