Features that may be missing in DO?
I have 2 questions.
  1. i currently have dual vertical view with 2 folder trees. Is it possible to rearrange (swap) the 4 panes (with each other)? It would be nice to have the folder trees on the sides (left and right), and the rest in the middle, so that I can drag and drop faster and won't have to drag over a folder tree all the time.
  2. is it possible to have multiple vertical file/folder panes (without folder tree) and every left pane is the parent folder of its corresponding right pane (kind of like the ebay category selection, just with the file system. I think MAC OS X has this feature)?
If it's not possible, maybe take them as suggestions for future versions :slight_smile:
Breadcrumbs navigation bar gives similar functionality.
