File Filter Control question
Hi, is it possible to customize the File Filter Control in a way to make it evaluate also the content of descript.ion files?
Not as far as I'm aware.
You can do it with the filters used in Find (Advanced), etc., but not with the filter text-box you can put on the toolbar.
