Hi,
Each time i right-click a file, the sort order changes for the file type groups items in the context-menu.
This was working correctly before 12.20.1
2 examples :
Are those items you've added yourself to the Music file type group, e.g. like this:
I tried with that setup and they always appear in the menu in the same order for me, at least so far.
If you want to send in the menu definitions, we can try with the same things here. You can save the details quickly by opening the File Types editor (Settings > File Types) and then using File > Diagnostic from the menu at the top of it, and entering mp3 as the extension:
That will make a zip file on your desktop. It usually won't contain anything sensitive but you can use a private message if you want to be sure.
I've added them myself in "file type groups", 1 entry per player.
No entry was added to Music file type group context menu.
Diagnostic sent in PM.
Thanks
Many thanks!
This has been fixed for the next beta which will most likely be released this week.
