Filename fonts change
I run Directory Opus and at the start and everything is displayed ok.
Folders names displayed with capital first letter then the rest of the name in lower case.
In the files window (right hand side), it displays the same as the folders for the first few minutes then the file names change to all capitals and some of the names shortened.
eg (PICT~01) instead of (Picture postcards.exe).
Could you please tell where I can find a setting to correct this? I've tried changing the fonts and font sizes but it made no difference.
Very new to Directory Opus.
Regards
Bluesticks11
That is usually caused by trying to bypass the copy-protection.
leo,
I only bought and downloaded the software yesterday
Receipt number .
Only used the trial version for a few days then bought full version.
Hi,
Please use GPSoftware: Support Request to request assistance.
Thanks!
