Filenames sorting in reverse order
For some reason DOpus is inverting the filename sorting option in folder formats. I have it setup so that it sorts them automatically, but it seems to do it in reverse order.
Here's an example of what the files are sorted like:
What I want it to be sorted like by default:
You might have Reverse Sort Order ticked on the Display tab of the format.
Danke.
